Security Overview and Situation Overview
Security Overview
On the Security Overview page, SecMaster displays the overall security assessment result of your assets in real time. SecMaster works together with other cloud security services to centrally display security assessment and monitoring results, as well as your cloud security scores over time. The Security Overview page displays the overall security assessment of all workspaces in real time. For details about how to view the result, see Checking Security Overview.
Situation Overview
The Situation Overview page displays the overall security assessment status of resources in the current workspace in real time. You will view the security assessment results, security monitoring details, and security trend of your assets. The page of the target workspace displays the security assessment result of the current workspace. For details about how to check the result, see Checking Situation Overview.
Security Risk
A security risk is a comprehensive evaluation of your assets, reflecting the security level of your assets within a period of time by a security score. A security score is for your reference to learn about the security situation of your assets. Overall Situation Screen can be used to reconstruct attack history, detect ongoing attack, and predict attack trends. With this screen, you will benefit from comprehensive pre-, during-, and post-incident security management.
Security Score
SecMaster displays the overall security assessment results of your assets on the cloud in real time and evaluates your overall asset security health score.
The security score is automatically updated at 02:00 every day. You can also click Check Again to update it immediately.
This following part describes how your security score is calculated.
- Security Score
SecMaster evaluates the over security posture of your assets based on the SecMaster edition you are using.
- There are six risk severity levels, Secure, Informational, Low, Medium, High, and Critical.
- The score ranges from 0 to 100. The higher the security score, the lower the risk severity level.
- The security score starts from 0 and the risk severity level is escalated up from Secure to the next level every 20 points. For example, for scores ranging from 40 to 60, the risk severity is Medium.
- The color keys listed on the right of the chart show the names of donut slices. Different color represents different risk severity levels. For example, the yellow slice indicates that your asset risk severity is Medium.
- If you have fixed asset risks and refreshed the alert status, you can click Check Again to update the security score.
After risks are fixed, manually ignore or handle alert incidents and update the alert incident status in the alert list. The risk severity can be down to a proper level accordingly.
Table 1 Security score table Severity
Security Score
Secure
100
Congratulations. Your assets are secure.
Informational
80 ≤ Security Score < 100
Your system should be hardened as several security risks have been detected.
Low
60 ≤ Security Score < 80
Your system should be hardened in a timely manner as too many security risks have been detected.
Medium
40 ≤ Security Score < 60
Your system should be hardened, or your assets will be vulnerable to attacks.
High
20 ≤ Security Score < 40
Detected risks should be handled immediately, or your assets will be vulnerable to attacks.
Critical
0≤ Security Score <20
Detected risks should be handled immediately, or your assets may be attacked.
- Unscored check items
The following table lists the security check items and corresponding points.
Table 2 Unscored check items Category
Unscored Item
Unscored Point
Suggestion
Maximum Unscored Point
Enabling of security services
Security-related services not enabled
No points deducted
Enable security-related services.
30
Compliance Check
Critical non-compliance items not fixed
10
Fix compliance violations by referring recommended fixes and start a scan again. The security score will be updated.
20
High-risk non-compliance items not fixed
5
Medium-risk non-compliance items not fixed
2
Low-risk non-compliance items not fixed
0.1
Vulnerabilities
Critical vulnerabilities not fixed
10
Fix vulnerabilities by referring corresponding suggestions and start a scan again. The security score will be updated.
20
High-risk vulnerabilities not fixed
5
Medium-risk vulnerabilities not fixed
2
Low-risk vulnerabilities not fixed
0.1
Threat Alerts
Critical alerts not fixed
10
Fix the threats by referring to the suggestions. The security score will be updated accordingly.
30
High-risk alerts not fixed
5
Medium-risk alerts not fixed
2
Low-risk alerts not fixed
0.1
