Help Center/ Object Storage Service/ User Guide (Kuala Lumpur Region)/ FAQ/ Tools/ How Do I Use the obsutil cp Command to Enable Incremental Upload, Download, or Replication?
Updated on 2025-01-26 GMT+08:00
When running the obsutil cp command to upload or download data, you can add the -u parameter to enable the incremental upload/download function.
This parameter indicates that the system will compare the source path with the target path when uploading, downloading, or replicating an object. The system uploads, downloads, or replicates an object only when the target object does not exist, the object size is inconsistent, or the last modification time of the target object is earlier than that of the source object.
