What Are the Application Scenarios of Lifecycle Management?
- Periodically delete logs that are only meant to be retained for a specific period of time (a week or a month).
 - Transition documents that are seldom accessed to the Warm or Cold storage class or delete them.
If you want to delete a large number of objects from a bucket, you can configure a lifecycle rule to automatically delete the expired objects. Table 1 lists the parameters for configuring such a lifecycle rule on OBS Console.
       Parameter  |
       Value  |
       Status  |
       Enable  |
       Rule Name  |
       Example: rule-delete  |
       Applies To  |
       You can apply the deletion rule to the entire bucket or to objects that share the same name prefix in the bucket.  |
       Current Version  |
       Expiration Time Days: 1  |
       Historical Version  |
One day later, objects in the bucket are successfully deleted based on the rule. If you no longer need this lifecycle rule, you can disable it or delete it.
