On this page
Creating a Bucket
Updated on 2025-01-26 GMT+08:00
A bucket is a container that stores objects in OBS. Before you store data in OBS, you need to create a bucket.
An account can create a maximum of 100 buckets and parallel file systems.
  1. In the upper right corner of the OBS Console homepage, click Create Bucket.
  2. Configure bucket parameters.
    Table 1 Bucket parameters
    Region
    Geographic area where a bucket resides. For low latency and faster access, select the region nearest to you. Once the bucket is created, its region cannot be changed.
    Bucket Name
    Name of the bucket. A bucket name must be unique across all accounts and regions. Once a bucket is created, its name cannot be changed.
    According to the globally applied DNS naming rules, an OBS bucket name:
    • Must be unique across all accounts and regions. The name of a deleted bucket can be reused for another bucket or a parallel file system at least 30 minutes after the deletion.
    • Must be 3 to 63 characters long. Only lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot start or end with a period (.) or hyphen (-), and cannot contain two consecutive periods (..) or contain a period (.) and a hyphen (-) adjacent to each other.
    • Cannot be formatted as an IP address.
      When you access OBS through HTTPS using virtual hosted-style URLs, if the bucket name contains a period (.), the certificate verification will fail. To work around this issue, you are advised not to use periods (.) in bucket names.
    Storage Class
    Storage classes of a bucket. Different storage classes meet different requirements for storage performance and costs.
    • The Standard storage class is for storing a large number of hot files or small files that are frequently accessed (multiple times per month on average) and require quick retrieval.
    • The Warm storage class is for storing data that is less frequently accessed (less than 12 times per year on average) and requires quick retrieval.
    • The Cold storage class is for archiving data that is rarely accessed (once a year on average) and has no requirements for quick retrieval.
    For details, see Storage Classes Overview.
    Bucket Policy
    Controls read and write permissions for buckets.
    • Private: No access beyond the bucket ACL settings is granted.
    • Public Read: Anyone can read objects in the bucket.
    • Public Read and Write: Anyone can read, write, or delete objects in the bucket.
    Default Encryption
    After you enable default encryption for the bucket, any object you upload to it will inherit the KMS encryption from the bucket by default.
    After you enable default encryption for the bucket, any object you upload to it will be encrypted with the obs/default key by default. You can also click Create KMS Key to create a key on the KMS console. Then select the created key on OBS Console for encryption.
    Enterprise Project
    You can add a bucket to an enterprise project for unified management.
    Create an enterprise project on the enterprise project page. The default enterprise project is named default.
    On the Enterprise Project Management page, create an enterprise project, create a user group and add users to this group, and then add the user group to the enterprise project. By doing so, users in this user group obtain the operation permissions for the buckets and objects in the enterprise project.
    Only an enterprise account can configure enterprise projects.
    OBS Viewer and OBS Operator are the fine-grained authorizations of the enterprise project user group in OBS.
    Tags
    Optional. Tags are used to identify and classify buckets in OBS. Each tag is represented by a key-value pair.
    For more information, see Tag Overview.
  3. Click Create Now.
Related Operations
After the bucket is created, you can change its storage class by performing the following steps:
  1. In the bucket list on OBS Console, select the target bucket and click Change Storage Class on the right.
  2. Select the desired storage class and click OK.
    • Changing the storage class of a bucket does not change the storage class of existing objects in the bucket.
    • If you do not specify a storage class for an object when uploading it, it inherits the bucket's storage class by default. After the bucket's storage class is changed, newly uploaded objects will inherit the new storage class of the bucket by default.
