Creating Log Groups and Log Streams
You have obtained an account and its password for logging in to the console.
Creating a Log Group
- Log in to the management console and choose Management & Deployment > Log Tank Service.
- On the Log Management page, click Create Log Group.
- In the dialog box displayed, set log group parameters by referring to Table 1.
Table 1 Log group parameters Parameter
Log Group Name
- Enter 1 to 64 characters, including only letters, digits, hyphens (-), underscores (_), and periods (.). Do not start with a period or underscore or end with a period.
- Collected logs are sent to log streams of the corresponding log groups. If there are too many logs to collect, separate logs into different log groups based on log types, and name log groups in an easily identifiable way.
Enterprise Project Name
Select an enterprise project. You can click View Enterprise Projects to view all enterprise projects.
Enterprise projects allow you to manage cloud resources and users by project.
Log Retention (Days)
Specify the log retention period for the log group, that is, how many days the logs will be stored in LTS after being reported to LTS.
By default, logs are retained for 30 days. You can set the retention period to one to 30 days.
Tag
Tag the log group as required. Click Add Tags, enter a tag key and value, and enable Apply to Log Stream.
- To add more tags, repeat this step. A maximum of 20 tags can be added.
- To delete a tag, click Delete in the Operation column of the tag.
- A tag key can contain up to 128 characters, and a tag value can contain up to 255 characters.
- A tag key must be unique.
- If a tag is used by a transfer task, you need to modify the task configuration after deleting the tag.
Remark
Enter remarks. The value contains up to 1,024 characters.
- Click OK. The created log group will be displayed in the log group list.
Creating a Log Stream
- Click
on the left of a log group name and click Create Log Stream. - In the dialog box displayed, set log stream parameters by referring to Table 2.
Table 2 Log stream parameters Parameter
Log Group Name
The name of the target log group is displayed by default.
Log Stream Name
Select the required enterprise project. The default value is default. You can click View Enterprise Projects to view all enterprise projects.
Specify the log retention period for the log stream, that is, how many days the logs will be stored in LTS after being reported to LTS.
- If you enable Log Retention (Days) for the log stream, logs are retained for the period set for the log stream.
- If you disable Log Retention (Days) for the log stream, logs are retained for the period set for the log group.
- The logs that exceed the retention period will be automatically deleted. You can transfer logs to OBS buckets for long-term storage.
Tag
You can tag log streams as required. Click Add Tags and enter a tag key and tag value.
Remark
- Click OK. The created log stream will be displayed under the target log group.
