Updated on 2025-03-27 GMT+08:00
Setting Structured and Tag Fields
Setting Structured Fields
You can set extracted fields after cloud structuring. For details, see Table 1.
Table 1 Rules for configuring structured fields
Structuring Method
Field Name
Field Type Can Be Changed
Field Can Be Deleted
Regular expressions (auto generate)
User-defined.
The name must start with a letter and contain only letters and digits.
Yes
Yes
Regular expressions (manually enter)
  • User-defined.
  • Default names such as field1, field2, and field3 will be used.
Yes
Yes
JSON
Names are set automatically, but you can set aliases for fields.
Yes
Yes
Delimiter
Default names such as field1, field2, field3 are used. You can modify these names.
Yes
Yes
Nginx
Names are set based on Nginx configuration, but you can set aliases for fields.
Yes
Yes
Custom templates
User-defined.
Yes
Yes
When you use regular expressions (manually entered), JSON, delimiters, Nginx, or custom templates to structure logs, field names:
Can contain 1 to 64 characters. Use only letters, digits, hyphens (-), underscores (_), and periods (.). Do not use underscores before another underscore or a period. Do not start or end with a period.
Setting Tag Fields
When configuring log structuring, you can set the tag fields for the log information.
  1. In Step 2 Extract fields, click the Tag Fields tab and Add Field.
  2. In the Field column, enter a name for the tag field, for example, hostIP.
    If you configure tag fields for a structuring rule that was created before the function of tag fields was brought online, no example values will be shown with the tag fields.
  3. To add more fields, click Add Field.
  4. Click Save.
    • Tag fields can be the following system fields: category, clusterId, clusterName, containerName, hostIP, hostId, hostName, nameSpace, pathFile, and podName.
    • Tag fields cannot be the following system fields: groupName, logStream, lineNum, content, logContent, logContentSize, and collectTime.
    • You can configure both field extraction and tag fields during log structuring.
