Updated on 2025-03-27 GMT+08:00
Setting Indexes
An index is a storage structure used to query and analyze logs. Different index settings will generate different query and analysis results. Configure the index settings as required.
Index Types
LTS supports full-text and field indexes. For details, see Table 1.
Table 1 Index types
Index Type
Index Whole Text
LTS splits all field values of an entire log into multiple words when this function is enabled.
  • The custom label field uploaded by the user is not included in the full-text index. If you want to search for the custom label field, add the corresponding index field.
  • System reserved fields are not included in full-text indexes. You need to use index fields (Key:Value) to search for them. For details, see System Reserved Fields.
Index Fields
Query logs by specified field names and values (Key:Value).
  • LTS creates index fields for certain system reserved fields by default. For details, see System Reserved Fields.
  • If an index field is configured for a field, the delimiter of the field value is subject to the index field configuration.
  • The quick analysis column in structuring settings has been removed. To use quick analysis, configure index fields and enable quick analysis for the required fields.
  • In the example log, the level and status index fields are configured. For the level field, it is of the string type, its value is error, and delimiters are configured. For the status field, it is of the long type, and no delimiter needs to be configured. You can use level:error to search for all logs whose level value is error.
  • In the example log, LTS creates indexes for system reserved fields such as hostName, hostIP, and pathFile by default.
The following is a typical example log. The value of the content field is the original log content. Use commas (,) to parse the original log content into three fields: level, status, and message.
In the example log, hostName, hostIP, and pathFile are common system reserved fields. For details about the system fields, see System Reserved Fields.
"hostName":"epstest-xx518",
"hostIP":"192.168.0.31",
"pathFile":"stdout.log",
"content":"error,400,I Know XX",
"level":"error",
"status":400,
"message":"I Know XX"
Precautions
  • Either whole text indexing or index fields must be configured.
  • After the index function is disabled, the storage space of historical indexes is automatically cleared after the data storage period of the current log stream expires.
  • Different index settings will generate different query and analysis results. Configure the index settings as required. Full-text indexes and index fields do not affect each other.
  • After the index configuration is modified, the modification takes effect only for newly written log data.
Configuring Full-Text Indexing
  1. Log in to the management console and choose Management & Deployment > Log Tank Service. The Log Management page is displayed by default.
  2. Expand the target log group and click the name of the target stream.
  3. Click next to Quick Analysis to go to the Index Settings tab page.
  4. Set index parameters by referring to Table 2. Index Whole Text is enabled by default.
    Table 2 Custom full-text indexing parameters
    Index Whole Text
    If Index Whole Text is enabled, a full-text index is created.
    Case-Sensitive
    Indicates whether letters are case-sensitive during query.
    • If this function is enabled, the query result is case-sensitive. For example, if the example log contains Know, you can query the log only with Know.
    • If this function is disabled, the query result is case-insensitive. For example, if the example log contains Know, you can also query the log with KNOW or know.
    Include Chinese
    Indicates whether to distinguish between Chinese and English during query.
    • After the function is enabled, if the log contains Chinese characters, the Chinese content is split based on unigram segmentation and the English content is split based on delimiters.
      • Unigram segmentation is to split a Chinese string into Chinese characters.
      • The advantage of unigram segmentation is efficient word segmentation of massive logs, and other Chinese segmentation methods have great impact on the write speed.
      • If Include Chinese is enabled, unigram segmentation is used for Chinese characters (each Chinese character is segmented separately). To obtain more accurate search results, use phrases with the syntax #"phrase to be searched for".
    • After this function is disabled, all content is split based on delimiters.
    For example, assume that the log content is:
    error,400,I Know TodayIsMonday.
    • After this function is disabled, the English content is split based on delimiters. The log is split into error, 400, I, Know, and TodayIsMonday. You can search for the log by error or TodayIsMonday.
    • After this function is enabled, the background analyzer of LTS splits the log into error, 400, I, Know, Today, Is, and Monday. You can search for the log by error or Today.
    Delimiters
    Splits the log content into multiple words based on the specified delimiters. If the default settings cannot meet your requirements, you can customize delimiters.
    If you leave Delimiters blank, the field value is regarded as a whole. You can search for logs only through a complete string or by fuzzy match.
    Click Preview the see the effect.
    • If no delimiter is set, the entire log is regarded as a string error,400,I Know TodayIsMonday. You can search for the log only by the complete string error,400,I Know TodayIsMonday or by fuzzy match error,400,I K*.
    • If the delimiter is set to a comma (,), the raw log is split into: error, 400, and I Know TodayIsMonday. You can search for the log by fuzzy or exact match, for example, error, 400, I Kn*, and TodayIs*.
    • If the delimiters are set to a comma (,) and space, the raw log is split into: error, 400, I, Know, TodayIsMonday. You can search for the log by fuzzy or exact match, for example, Know, and TodayIs*.
    ASCII Delimiters
    Click Add ASCII Delimiter and enter the ASCII value by referring to ASCII Table.
  5. Click OK.
Configuring Index Fields
When creating a field index, you can add a maximum of 500 fields. A maximum of 100 subfields can be added for JSON fields.
  1. Specify the number of samples for quick analysis. The value ranges from 100,000 (default) to 10 million. Quick analysis provides a fast overview by sampling field value statistics rather than analyzing all log data. The more logs sampled, the slower the analysis.
  2. Click Add Field under Index Fields to configure field indexing. For details, see Table 3.
    • The indexing parameters take effect only for the current field.
    • Index fields that do not exist in log content are invalid.
    • For details about the system fields, see System Reserved Fields.
    • Automatically configuring field indexes: Click Auto Configure. LTS generates field indexes based on the first log event in the preview or common system reserved fields (such as hostIP, hostName, and pathFile). You can add or delete fields as required.
    • Configuring field indexes in batches: Select fields and click Batch Configure.
    • For automatic configuration, LTS obtains the intersection of the raw logs and system fields in the last 15 minutes by default, and combines the intersection with current structured fields and tag fields to form the table data below Index Fields.
    • If no raw log is generated in the last 15 minutes, LTS obtains hostIP, hostName, pathFile, structured fields, and tag fields to form the table data.
    • When structuring is configured for ECS ingestion, the category, hostName, hostId, hostIP, hostIPv6 and pathFile fields are automatically added to Index Fields on the Index Settings page. A field will not be added if the same one already exists.
    • When structuring is configured for CCE ingestion, the category, clusterId, clusterName, nameSpace, podName, containerName, appName, hostName, hostId, hostIP, hostIPv6 and pathFile fields are automatically added to Index Fields on the Index Settings page. A field will not be added if the same one already exists.
    Table 3 Custom index field parameters
    Field
    Log field name, such as level in the example log.
    • A field name can contain only letters, digits, hyphens (-), underscores (_), and periods (.). Do not use an underscore before another underscore or a period. Do not start or end with a period.
    • Double underscores (__) are used in built-in reserved fields that are not displayed to users in LTS. Avoid using them in custom log field names, as this will prevent the configuration of field index names.
    • For system fields, system is displayed next to their names.
    Action
    Displays the field status, such as New, Retain, Modify, and Delete. After the index field is changed, click Compare to view the differences between the original and modified configurations.
    • New fields cannot be modified.
    • When you modify the settings of Type, Case-Sensitive, Common Delimiters, ASCII Delimiters, Include Chinese, or Quick Analysis, the system compares the modified settings with the original settings and changes the action to modified.
    • After you click OK, the fields whose action is deleted are not saved.
    Type
    • Data type of the log field value. The options are string, long, and float.
    • Fields of long and float types do not support Case-Sensitivity, Include Chinese, and Delimiters.
    Case-Sensitive
    • If this function is enabled, the query result is case-sensitive. For example, if the message field in the example log contains Know, you can query the log only with message:Know.
    • If this function is disabled, the query result is case-insensitive. For example, if the message field in the example log contains Know, you can also query the log with message:KNOW or message:know.
    Common Delimiters
    For example, the content of the message field in the example log is I Know TodayIsMonday.
    • If no delimiter is set, the entire log is regarded as a string I Know TodayIsMonday. You can search for the log only by the complete string message:I Know TodayIsMonday or by fuzzy search message:I Know TodayIs*.
    • If the delimiter is set to a space, the raw log is split into: I, Know, and TodayIsMonday. You can find the log by fuzzy search or exact words, for example, message:Know, or message: TodayIsMonday.
    ASCII Delimiters
    Include Chinese
    • After this function is disabled, the English content is split based on delimiters. The log is split into I, Know, and TodayIsMonday. You can search for the log by message:Know or message:TodayIsMonday.
    • After this function is enabled, the background analyzer of LTS splits the log into I, Know, Today, Is, and Monday. You can search for the log by message:Know or message:Today.
    Quick Analysis
    By default, this option is enabled, indicating that this field will be sampled and collected. For details, see Creating an LTS Quick Analysis Task.
    • The principle of quick analysis is to collect statistics on 100,000 logs that match the search criteria, not all logs.
    • The maximum length of a field for quick analysis is 2,000 bytes.
    • The quick analysis field area displays the first 100 records.
    Operation
    Click to delete the target field.
  3. Click OK.
During log collection, LTS adds information such as the collection time, log type, and host IP address to logs in the form of Key-Value pairs. These fields are system reserved fields.
  • When using APIs to write log data or add ICAgent configurations, avoid using the same field names as reserved field names to prevent issues such as duplicate field names and incorrect queries.
  • A custom log field must not contain double underscores (__) in its name. If it does, indexing cannot be configured for the field.
Table 4 System reserved field description
Field
Data Format
Index and Statistics Settings
collectTime
Integer, Unix timestamp (ms)
Index setting: After indexing is enabled, a field index is created for collectTime by default. The index data type is long.
Enter collectTime : xxx during the query.
Indicates the time when logs are collected by ICAgent.
Example: "collectTime":"1681896081334" indicates 2023-04-19 17:21:21 when converted into standard time.
__time__
Index setting: After indexing is enabled, a field index is created for time by default. The index data type is long. This field cannot be queried.
Log time refers to the time when a log is displayed on the console.
Example: "__time__":"1681896081334" indicates 2023-04-19 17:21:21 when converted into standard time.
By default, the collection time is used as the log time. You can also customize the log time.
lineNum
Integer
Index setting: After indexing is enabled, a field index is created for lineNum by default. The index data type is long.
Line number (offset), which is used to sort logs.
Non-high-precision logs are generated based on the value of collectTime. The default value is collectTime * 1000000 + 1. For high-precision logs, the value is the nanosecond value reported by users.
Example: "lineNum":"1681896081333991900"
category
String
Index setting: After indexing is enabled, a field index is created for category by default. The index data type is string, and the delimiters are empty. Enter category: xxx during the query.
Log type, indicating the source of the log.
Example: The field value of logs collected by ICAgent is LTS, and that of logs reported by a cloud service such as DCS is DCS.
clusterName
String
Index setting: After indexing is enabled, a field index is created for clusterName by default. The index data type is string, and the delimiters are empty. Enter clusterName: xxx during the query.
Cluster name, used in the Kubernetes scenario.
Example: "clusterName":"epstest"
clusterId
String
Index setting: After indexing is enabled, a field index is created for clusterId by default. The index data type is string, and the delimiters are empty. Enter clusterId: xxx during the query.
Cluster ID, used in the Kubernetes scenario. Example: "clusterId":"c7f3f4a5-xxxx-11ed-a4ec-0255ac100b07"
nameSpace
String
Index setting: After indexing is enabled, a field index is created for nameSpace by default. The index data type is string, and the delimiters are empty. Enter nameSpace: xxx during the query.
Namespace used in the Kubernetes scenario.
Example: "nameSpace":"monitoring"
appName
String
Index setting: After indexing is enabled, a field index is created for appName by default. The index data type is string, and the delimiters are empty. Enter appName: xxx during the query.
Component name, that is, the workload name in the Kubernetes scenario.
Example: "appName":"alertmanager-alertmanager"
serviceID
String
Index setting: After indexing is enabled, a field index is created for serviceID by default. The index data type is string, and the delimiters are empty. Enter serviceID: xxx during the query.
Workload ID in the Kubernetes scenario.
Example: "serviceID":"cf5b453xxxad61d4c483b50da3fad5ad"
podName
String
Index setting: After indexing is enabled, a field index is created for podName by default. The index data type is string, and the delimiters are empty. Enter podName: xxx during the query.
Pod name in the Kubernetes scenario.
Example: "podName":"alertmanager-alertmanager-0"
podIp
String
Index setting: After indexing is enabled, a field index is created for podIp by default. The index data type is string, and the delimiters are empty. Enter podIp: xxx during the query.
Pod IP address in the Kubernetes scenario.
Example: "podIp":"10.0.0.145"
containerName
String
Index setting: After indexing is enabled, a field index is created for containerName by default. The index data type is string, and the delimiters are empty. Enter containerName: xxx during the query.
Container name used in the Kubernetes scenario.
Example: "containerName":"config-reloader"
hostName
String
Index setting: After this function is enabled, a field index is created for hostName by default. The index data type is string, and the delimiters are empty. Enter hostName: xxx during the query.
Indicates the host name where ICAgent resides.
Such as "hostName":"epstest-xx518" in the example.
hostId
String
Index setting: After this function is enabled, a field index is created for hostId by default. The index data type is string, and the delimiters are empty. Enter hostId: xxx during the query.
Indicates the host ID where ICAgent resides. The ID is generated by ICAgent. Such as "hostId":"318c02fe-xxxx-4c91-b5bb-6923513b6c34" in the example.
hostIP
String
Index setting: After this function is enabled, a field index is created for hostIP by default. The index data type is string, and the delimiters are empty. Enter hostIP: xxx during the query.
Host IP address where the log collector resides (applicable to IPv4 scenario)
Such as "hostIP":"192.168.0.31" in the example.
hostIPv6
String
Index setting: After this function is enabled, a field index is created for hostIPv6 by default. The index data type is string, and the delimiters are empty. Enter hostIPv6: xxx during the query.
Host IP address where the log collector resides (applicable to IPv6 scenario)
Such as "hostIPv6":"" in the example.
pathFile
String
Index setting: After this function is enabled, a field index is created for pathFile by default. The index data type is string, and the delimiters are empty. Enter pathFile: xxx during the query.
File path is the path of the collected log file.
Such as "pathFile":"stdout.log" in the example.
content
String
Index setting: After Index Whole Text is enabled, the delimiters defined in Index Whole Text are used to delimit the value of the content field. The content field cannot be configured in the field index.
Original log content.
Example: "content":"level=error ts=2023-04-19T09:21:21.333895559Z"
__receive_time__
Index setting: After this function is enabled, a field index is created for __receive_time__ by default. The index data type is long.
Time when a log is reported to the server, which is same as the time when the LTS collector receives the log.
_content_parse_fail_
String
Index setting: After indexing is enabled, a field index is created for _content_parse_fail_ by default. The index data type is string, and the default delimiter is used. Enter _content_parse_fail_: xxx during the query.
Content of the log that fails to be parsed.
__time
The __time field cannot be configured in the field index.
N/A
logContent
String
The logContent field cannot be configured in the field index.
N/A
logContentSize
Integer
The logContentSize field cannot be configured in the field index.
N/A
logIndexSize
Integer
The logIndexSize field cannot be configured in the field index.
N/A
groupName
String
The groupName field cannot be configured in the field index.
N/A
logStream
String
The logStream field cannot be configured in the field index.
N/A
ASCII Table
Table 5 ASCII table
ASCII Value
Character
ASCII Value
Character
ASCII Value
Character
ASCII Value
Character
0
NUL (Null)
32
Space
64
96
SOH (Start of heading)
33
65
A
97
a
2
STX (Start of text)
34
66
B
98
b
3
ETX (End of text)
35
67
C
99
c
4
EOT (End of transmission)
36
68
D
100
d
5
ENQ (Enquiry)
37
69
E
101
e
6
ACK (Acknowledge)
38
70
F
102
f
7
BEL (Bell)
39
71
G
103
g
8
BS (Backspace)
40
72
H
104
h
9
HT (Horizontal tab)
41
73
I
105
i
10
LF (Line feed)
42
74
J
106
j
11
VT (Vertical tab)
43
75
K
107
k
12
FF (Form feed)
44
76
L
108
l
13
CR (Carriage return)
45
77
M
109
m
14
SO (Shift out)
46
78
N
110
n
15
SI (Shift in)
47
79
O
111
o
16
DLE (Data link escape)
48
0
80
P
112
p
17
DC1 (Device control 1)
49
Q
113
q
18
DC2 (Device control 2)
50
2
82
R
114
r
19
DC3 (Device control 3)
51
3
83
S
115
s
20
DC4 (Device control 4)
52
4
84
T
116
t
21
NAK (Negative acknowledge)
53
5
85
U
117
u
22
SYN (Synchronous idle)
54
6
86
V
118
v
23
ETB (End of transmission block)
55
7
87
W
119
w
24
CAN (Cancel)
56
8
88
X
120
x
25
EM (End of medium)
57
9
89
Y
121
y
26
SUB (Substitute)
58
90
Z
122
z
27
ESC (Escape)
59
91
123
28
FS (File separator)
60
92
124
29
GS (Group separator)
61
93
125
30
RS (Record separator)
62
94
126
31
US (Unit separator)
63
95
_
127
DEL (Delete)
