Managing Tags
You can tag log groups, log streams, host groups, and log ingestion configurations.
Tagging a Log Group
Users can add, delete, modify, and query tags on the log group page.
- Log in to the management console and choose Management & Deployment > Log Tank Service.
- On the Log Management page, move the cursor to the Tags column of the target log group and click
. - On the Edit page that is displayed, click Add Tags and enter a tag key and value. If you enable Apply to Log Stream, the tag will be synchronized to all log streams in the log group.
Figure 1 Adding a tag
- To add multiple tags, repeat this step.
- To delete a tag, click Delete in the Operation column of the tag.
- A tag key can contain up to 128 characters, and a tag value can contain up to 255 characters.
- A tag key must be unique.
- If a tag is used by a transfer task, you need to modify the task configuration after deleting the tag.
- Click OK.
On the Log Management page, you can view the added tags in the Tags column of the log group.
Tagging a Log Stream
You can add, delete, modify, and view tags on the log stream list page. When you manage the tags of a single log stream, the changes will not be synchronized to other streams.
- Click
in front of the name of the target log group. - Move the cursor to the Tags column of the target log stream and click
Figure 2 Editing a tag
- Click OK.
In the log stream list, you can view the system tags and added custom tags in the Tags column of the log stream.
Tagging a Host Group
You can add, delete, modify, and view tags of host groups. When you manage the tags of a single host group, the changes will not be synchronized to other groups.
- Choose Host Management > Host Groups in the navigation pane.
- Locate the target host group and click Configure Tag in the Operation column.
- Click OK. You can view the added tags in the Tags column of the host group.
Tagging a Log Ingestion Configuration
You can add, delete, modify, and view tags of log ingestion configurations. When you manage the tags of a single log ingestion configuration, the changes will not be synchronized to other configurations.
- In the navigation pane, choose Log Ingestion > Ingestion Management.
- Locate the target log ingestion configuration and click Configure Tag in the Operation column.
- To delete a tag, click Delete next to the tag on the tag management dialog box.
- Click OK. You can view the added tags in the Tags column of the log ingestion configuration.
