Updated on 2025-03-27 GMT+08:00
Overview
Log ingestion is crucial for LTS, as it collects various log data generated during the execution of applications or services, including system statuses, errors, and user operation records. LTS stores the data in a specific location for subsequent analysis and application, which is critical to system O&M, troubleshooting, and service analysis.
LTS enables real-time log ingestion via various methods. Logs can be collected using ICAgent, ingested from cloud services, or reported to LTS via custom software or APIs. Subsequently, you can perform operations on these logs using the LTS console, such as searching and analyzing logs, visualizing log statistics in charts or dashboards, and setting alarm reporting and log transfer.
Before configuring log ingestion, ensure that ICAgent collection is enabled by referring to Setting LTS Log Collection Quota.
  • This function is enabled by default. If you do not need to collect logs, disable this function to reduce resource usage.
  • After this function is disabled, ICAgent will stop collecting logs, and the log collection function on the AOM console will also be disabled.
