API for Reporting High-Precision Logs
Function
This API is used to report tenant logs from a host to LTS.
The access IP address is contained in the ICAgent installation command displayed on the LTS console. The port number is 8102. You can check the Example Request to see how to add the access IP address and port number in a request.
Each log event will carry a nanosecond-level timestamp when it is reported. When you view logs on the LTS console, the log events are sorted by timestamp.
URI
POST /v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents/high-accuracy
Parameter |
Mandatory |
Type |
Description |
project_id |
Yes |
String |
Project ID. For details about how to obtain it, see . Value length: 32 characters |
log_group_id |
Yes |
String |
Log group ID. For details about how to obtain it, see . Value length: 36 characters |
log_stream_id |
Yes |
String |
Log stream ID. For details about how to obtain it, see . Value length: 36 characters A write rate exceeding 100 MB/s per log stream may cause log losses. |
Request Parameters
Parameter |
Mandatory |
Type |
Description |
X-Auth-Token |
Yes |
String |
Indicates the user token obtained from IAM. Minimum length: 1,000 characters Maximum length: 2,000 characters |
Content-Type |
Yes |
String |
Set this parameter to application/json;charset=UTF-8. Minimum length: 30 characters Maximum length: 30 characters |
Content-Encoding |
No |
String |
Log compression format. Example value:
Parameter |
Mandatory |
Type |
Description |
contents |
Yes |
Array of LogContents |
Indicates a list of log events that carry reporting timestamps. |
labels |
Yes |
Object |
Custom labels. |
tenant_project_id |
No |
String |
Project ID. For details about how to obtain it, see . |
Parameter |
Mandatory |
Type |
Description |
log_time_ns |
Yes |
Long |
Time when log data is reported (UTC time in nanoseconds). Logs reported to LTS through APIs are retained for two days (from the log reporting time to the current time). Logs reported more than two days ago will be deleted. |
log |
Yes |
String |
Indicates the log content. |
Response Parameters
When the status code is 200, the response parameters are as follows:
Parameter |
Type |
Description |
errorCode |
String |
Indicates the error code. |
error_msg |
String |
Indicates the response description. |
result |
String |
Response result. |
When the status code is 400, the response parameters are as follows:
Parameter |
Type |
Description |
errorCode |
String |
error_msg |
String |
Indicates the error description. |
result |
String |
Response result. |
When the status code is 401, the response parameters are as follows:
Parameter |
Type |
Description |
errorCode |
String |
error_msg |
String |
result |
String |
Response result. |
When the status code is 500, the response parameters are as follows:
Parameter |
Type |
Description |
errorCode |
String |
error_msg |
String |
result |
String |
Response result. |
When the status code is 503, the response parameter is as follows:
Parameter |
Type |
Description |
result |
String |
The requested service is unavailable. |
Example Request
POST https://{access_IP_address:8102}/v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents/high-accuracy
"contents": [
"log_time_ns": 1586850540000000000,
"log": "Fri Feb 15 15:48:04 UTC 2019"
"log_time_ns": 1586850540000000001,
"log": "Sat April 18 16:04:04 UTC 2019"
"labels": {
"user_tag": "string"
Example Response
Example response with status code 200:
Logs are reported.
"errorCode": "SVCSTG.ALS.200.200",
"error_msg": "Report success.",
"result": null
Example response with status code 401:
The authentication information is incorrect or invalid.
"errorCode" : "SVCSTG.ALS.403.105",
"error_msg" : "Project id is invalid.",
"result": null
Status Code
Status Code |
Description |
200 |
The request has succeeded. |
400 |
The request is invalid. Modify the request based on the description in error_msg before a retry. |
401 |
The authentication information is incorrect or invalid. |
500 |
An internal error occurred. |
503 |
