Reporting Logs
Updated on 2023-11-29 GMT+08:00
Function
This API is used to report tenant logs from a host to LTS.
To obtain the access IP address, log in to the LTS console, choose Host Management in the navigation pane, and click Install ICAgent in the upper right corner. The access IP address is contained in the ICAgent installation command. The port number is 8102. You can check the Example Request to see how to add the access IP address and port number in a request.
URI
POST /v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents
Table 1 URI parameters
Mandatory
Type
project_id
Yes
String
Project ID. For details about how to obtain the project ID, see .
No default value.
Value length: 32 characters
log_group_id
Yes
String
Log group ID. For details about how to obtain the log group ID, see .
No default value.
Value length: 36 characters
log_stream_id
Yes
String
Log stream ID. For details about how to obtain the log stream ID, see .
No default value.
The write rate at most should not exceed 100 MB/s for a single log stream. Otherwise, logs may be lost.
Request Parameters
Table 2 Request header parameters
Mandatory
Type
X-Auth-Token
Yes
String
Indicates the user token obtained from IAM.
No default value.
Minimum length: 1000 characters
Maximum length: 2000 characters
Content-Type
Yes
String
Set this parameter to application/json;charset=UTF-8.
Default value: None
Minimum length: 30 characters
Maximum length: 30 characters
Table 3 Request body parameters
Mandatory
Type
log_time_ns
Yes
Long
Indicates the log collection time (UTC time in nanoseconds).
The interval between the log collection time and current time must be less than the log retention duration. Otherwise, reported logs will be cleared. For example, if the log retention duration is seven days, the log collection time must be within the last seven days.
contents
Yes
Array of String
Indicates the log content.
labels
Yes
Object
Custom labels.
tenant_project_id
No
String
Tenant ID.
Response Parameters
When the status code is 200, the response parameters are as follows:
Table 4 Response body parameters
Type
errorCode
String
Indicates the status code.
Example value:
  • SVCSTG.ALS.200.200
errorMessage
String
Indicates the response description.
Example value:
  • Report success.
result
String
Response result.
When the status code is 400, the response parameters are as follows:
Table 5 Response body parameters
Type
errorCode
String
Indicates the error code.
Example value:
  • SVCSTG.ALS.200.201
  • SVCSTG.ALS.200.210
errorMessage
String
Indicates the error description.
Example value:
  • Request conditions must be json format.
  • projectid xxx log's quota has full!!
result
String
Response result.
When the status code is 401, the response parameters are as follows:
Table 6 Response body parameters
Type
errorCode
String
Example value:
  • SVCSTG.ALS.403.105
errorMessage
String
Example value:
  • Project id is invalid.
result
String
Response result.
When the status code is 500, the response parameters are as follows:
Table 7 Response body parameters
Type
errorCode
String
Example value:
errorMessage
String
Example value:
  • Internal error
result
String
Response result.
When the status code is 503, the response parameter is as follows:
Table 8 Response body parameter
Type
result
String
The requested service is unavailable.
Example Request
POST https://{access_IP_address:8102}/v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents
	"log_time_ns": "1586850540000000000",
	"contents": [
		"Fri Feb  1 07:48:04 UTC 2019 0\n",
		"Sat Apri 18 16:04:04 UTC 2019"
	"labels": {
		"user_tag": "string"
Example Response
Example response with status code 200:
Logs are reported.
  "errorCode": "SVCSTG.ALS.200.200",
  "errorMessage": "Report success.",
  "result": null
Example response with status code 401:
The authentication information is incorrect or invalid.
  "errorCode" : "SVCSTG.ALS.403.105",
  "errorMessage" : "Project id is invalid.",
  "result": null
Status Code
Status Code
200
The request has succeeded.
400
The request is invalid. Modify the request based on the description in error_msg before a retry.
401
500
An internal error occurred.
503
