Granting LTS Permissions to IAM Users
You can use Identity and Access Management (IAM) for fine-grained permissions control for your LTS. With IAM, you can:
- Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing LTS resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust or a cloud service to perform efficient O&M on your LTS resources.
If your does not require individual IAM users, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before granting permissions to user groups, learn about system-defined permissions in Permissions Management for LTS.
Process Flow
- Log in to the IAM console. Create a user group on the IAM console and assign the LTS FullAccess permissions to the group. For details, see section "Creating a User Group and Assigning Permissions" in the IAM User Guide.
- Create a user on the IAM console and add the user to the user group created in 1. For details, see section "Creating a User and Adding the User to a User Group" in the IAM User Guide.
- Log in to the LTS console as the created user, switch to the authorized region, and verify your permissions by performing operations on the console. For details, see section "Logging In as a User" in the IAM User Guide.
