Managing Log Groups
Updated on 2023-11-29 GMT+08:00
A log group is a group of log streams. Up to 100 log groups can be created for a single account.
You have obtained an account and its password for logging in to the console.
Creating a Log Group
Log groups can be created in two ways. They are automatically created when other services interconnect with LTS, or you can create one manually by following the steps described here.
  1. Log in to the LTS console, choose Log Management in the navigation pane on the left, and click Create Log Group in the upper right corner.
  2. In the dialog box displayed, enter a log group name.
    • Collected logs are sent to the log group. If there are too many logs to collect, separate logs into different log groups based on log types, and name log groups in an easily identifiable way. After a log group is created, its name cannot be changed.
    • The log name can contain 1 to 64 characters, including only letters, digits, hyphens (-), underscores (_), and periods (.). It cannot start with a period or underscore or end with a period.
  3. Set Log Retention Duration. You can set it to 1 to 30 days.
    Figure 1 Creating a log group
  4. Enter remarks. The value contains 0 to 1024 characters.
  5. Click OK.
    • In the log group list, you can view the log group name, number of log streams, tags, and the Operation column of each log group.
    • Click the log group name, the details page of one of its log streams is displayed.
    • When multiple log groups are created concurrently, there may be a limit exceeding error.
Modifying a Log Group
You can modify the log retention duration or remarks of a log group by performing the following steps:
  1. In the log group list, locate the target log group and click Modify in the Operation column.
  2. Modify the log storage duration on the displayed page.
    Figure 2 Modifying a log group
  3. Click OK.
Deleting a Log Group
You can delete a log group that is no longer needed. Deleting a log group will also delete the log streams and log data in the log group. Deleted log groups cannot be recovered. Exercise caution when performing the deletion.
If you want to delete a log group that is associated with a log transfer task, delete the task first.
  1. In the log group list on the Log Management page, locate the target log group and click Delete in the Operation column.
  2. Enter DELETE and click OK.
Other Operations
To view the details of a log group, go to the log group list and click Details in the Operation column of the desired log group, including the log group name, ID, and creation time.
