Updated on 2025-10-10 GMT+08:00
Installing an Agent on the Proxy Server
Install an agent on the proxy server. Ensure the network is available and configure Nginx.
  2. Click in the upper left corner and select the region and project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane, choose Installation & Configuration > Server Install & Config.
  5. Choose Agents > Servers Without Agents.
  6. In the Operation column of the target server, click Install Agent. The Install Agent dialog box is displayed.
  7. Select and set the server verification information.
    • Server authentication mode: Select a mode. In this example, select Account and password mode.
    • Allow direct connection as user root: Depends on whether the server allows direct connection as user root. In this example, select this option.
      • Server Root Password: Set this parameter based on the server information.
      • Server Login Port: Set this parameter based on the actual server login port. In this example, set 22 port.
  1. Click OK to start installation.
  2. Choose Servers With Agents page and view the agent status of the target server.
    If the Agent Status is Online, the agent is successfully installed.
