Updated on 2025-10-10 GMT+08:00
Configuring Common Login IP Addresses
Common Login IP addresses are the IP addresses of the devices where normal users often log in to servers. After you configure common IP addresses, HSS will generate alarms on the logins from other IP addresses.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. Choose Installation & Configuration > Server Install & Config and click the Security Configuration tab. Click Common Login IP Addresses and click Add Common Login IP Address.
  1. In the dialog box that is displayed, enter a common login IP address and select servers. Confirm the information and click OK. For more information, see Table 1.
    Table 1 Parameters for adding a protected directory
    Enter a common login IP address.
    Enter an IP address or CIDR block. The requirements are as follows:
    • You can add only one IP address or CIDR block at a time. To add multiple values, repeat the operation.
      Example:
      • IP address: 192.78.10.3 or fe80::1
      • CIDR block: 192.78.10.0/255.255.255.0, 192.78.10.0/24, or fe80::1:0/112
    • You can add a maximum of 20 login IP addresses.
    Select the servers configured with the common login IP address.
    Select the servers where you wish to apply the common login IP addresses. You can select multiple servers at a time.
  2. Return to the Security Configuration tab of the Installation & Configuration page. Check whether the added locations are displayed on the Common Login IP Addresses subtab.
