Enabling Web Tamper Protection
The HSS web tamper protection (WTP) edition can protect dynamic and static web pages from being tampered with, enhancing the security and integrity of website content. It also includes the server protection capabilities of the premium edition, such as asset management, vulnerability detection, baseline check, intrusion detection, and ransomware protection, to detect attacks on servers.
This section describes how to enable WTP.
- Ensure that the agent has been installed on the server and is online. For details, see Installing the Agent on Cloud Platform Servers.
- After the Windows firewall is enabled, HSS automatically adds firewall rules hostguard_AllowAnyIn and hostguard_AllowAnyOut to allow all inbound and outbound traffic. This ensures that the firewall does not affect your services. If HSS detects a brute-force attack, it adds an inbound rule to the firewall to block the attack source IP address. This does not affect your servers.
- Do not disable the Windows firewall when using HSS, or HSS cannot block the source IP addresses of brute-force attacks. Once it is disabled, HSS may fail to block the attack source IP addresses even after you manually enable it again.
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Server Protection > Web Tamper Protection. On the Web Tamper Protection page, click Add Server.
- On the Add Server page, click the Available Servers tab. Select the target server, and click Add and Enable Protection.
- You can check the server protection status on the Web Tamper Protection page.
- Choose Server Protection > Web Tamper Protection. If the Protection Status of the server is Protected, WTP has been enabled.
- After WTP is enabled for a website, if you need to update the website, add a privileged process or temporarily disable WTP. Enable WTP after the update is complete. Otherwise, the website will fail to be updated. Your website is not protected while WTP is disabled. Enable it immediately after updating your website.
Advanced Defense Functions
HSS provides a series of advanced defense functions. You can enable or use them as required to enhance the security protection level of your servers. For details, see Table 2.
Function |
Description |
To protect your applications with RASP, you simply need to add probes to them, without having to modify application files. |
The function can detect and defend against ransomware. It can automatically back up data either at a scheduled time, or immediately if ransomware is detected. This can help you defend against ransomware and reduce loss. Ransomware prevention is automatically enabled with the container edition. HSS will deploy honeypot files on servers and automatically isolate suspicious encryption processes. You can modify the ransomware protection policy. |
Application process control helps to enhance the security of applications and processes running on servers. It can automatically identify and analyze application processes, and classify them into trusted, suspicious, and malicious processes. It allows trusted processes to run, and generates alarms for suspicious and malicious processes. This helps to build a secure environment for application processes, and protects servers from untrusted or malicious application processes. |
This function combines cloud-based and local antivirus mechanisms to scan executable files, compressed files, scripts, documents, images, and audiovisual files for viruses. You can perform quick scan, full-disk scan, and custom scans on servers as needed to detect and remove virus files in a timely manner, enhancing the virus defense of the system. |
The dynamic port honeypot function is a proactive defense measure. It uses a real port as a honeypot port to induce attackers to access the network. In the horizontal penetration scenario, the function can effectively detect attackers' scanning, identify faulty servers, and protect real resources of the user. |
