Updated on 2025-10-10 GMT+08:00
Monitored HSS Events
Feature Description
You can monitor the agent status using Cloud Eye. If the agent is offline unexpectedly or the agent protection status is abnormal, an alarm will be generated, notifying you of the HSS protection status in a timely manner.
After alarm notifications are enabled, you can view details about the reported alarms and events on the Event Monitoring page of the Cloud Eye console.
Namespace
SYS.HSS
Monitored Events
Table 1 Monitored HSS events
Event Name
Event ID
Severity
Suggestion
Impact
HSS agent disconnected
hssAgentAbnormalOffline
Major
The communication between the agent and the server is abnormal, or the agent process on the server is abnormal.
Fix your network connection. If the agent is still offline for a long time after the network recovers, the agent process may be abnormal. In this case, log in to the server and restart the agent process.
Service interruption
Abnormal HSS agent status
hssAgentAbnormalProtection
Major
The agent is abnormal probably because it does not have sufficient resources.
Log in to the server and check your resources. If the usage of memory or other system resources is too high, increase their capacity first. If the resources are sufficient but the fault persists after the agent process is restarted, submit a service ticket to the O&M personnel.
