Updated on 2025-10-10 GMT+08:00
Managing Manual Baseline Check Policies
This section describes how to modify a created manual baseline check policy.
Editing a Manual Baseline Check Policy
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane on the left, choose Prediction > Baseline Checks.
    If your servers are managed by enterprise projects, you can select an enterprise project to view or operate the asset and scan information.
  1. Click Policies in the upper right corner of the page.
  2. Click Edit in the Operation column of a policy. On the policy details page that is displayed, configure the policy name and check items.
    If you select Linux for OS, you can select any checks included in Baseline and edit rules. This function is not supported for Windows servers.
  3. Confirm the configuration, click Next, and select servers.
  4. Confirm the information and click OK. You can view the updated policy in the policy list.
Deleting a Manual Baseline Check Policy
  2. Click in the upper left corner of the page, select a region, and choose Security > Host Security Service. The HSS page is displayed.
  3. In the navigation pane on the left, choose Prediction > Baseline Checks.
  4. Click Policies in the upper right corner of the page.
  5. Click Delete in the Operation column of a policy. In the dialog box that is displayed, confirm the information and click OK.
    Only user-defined policies can be deleted. Default policies default_linux_security_check_policy and default_windows_security_check_policy cannot be deleted.
