Enabling/Disabling Scheduled Static WTP
You can schedule WTP protection to allow website updates in specific periods.
Exercise caution when you set the periods to disable WTP, because files will not be protected in those periods.
Rules for Setting an Unprotected Period
- Unprotected period >= 5 minutes
- Unprotected period < 24 hours
- Periods (except for those starting at 00:00 or ending at 23:59) cannot overlap and must have at least a 5-minute interval.
- A period cannot span two days.
- The server time is used as a local time base.
- Click
in the upper left corner of the page, select a region, and choose Security > Host Security Service. The HSS page is displayed.
- Choose Server Protection > Web Tamper Protection. Click Configure Protection in the Operation column.
If your servers are managed by enterprise projects, you can select an enterprise project to view or operate the asset and scan information.
- On the Configure Protection tab, click Settings under Scheduled Protection.
- Set the unprotected period and days in a week to automatically disable protection.
- Click Add Unprotected Period. Configure parameters in the dialog box that is displayed.
Configuration constraints:
- The server time is used as a time base.
- Click OK.
- Select the days to disable protection.
For example, if you select Mon., Thu., and Sat., the server automatically disables the WTP function during the unprotected period on these days.
- Click OK.
- Return to the Configure Protection tab and toggle on
to enable Scheduled Protection.
