Updated on 2025-10-10 GMT+08:00
Connecting to a Third-party Image Repository
HSS can connect to third-party image repositories and provides security detection and management capabilities for vulnerabilities, baselines, and malicious files, helping you detect security risks in images in a timely manner. This section describes how to connect a third-party image repository to HSS.
Prerequisite
The repository cluster (cluster where the repository is deployed) has been connected to HSS and is in the Running state. For details, see Installing the Agent on Containers.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane, choose Installation & Configuration > Container Install & Config.
  5. Click the Third-Party Image Repository tab.
  6. Click Connect to Third-Party Image Repository.
  7. Enter the required information as prompted. For details about the parameters, see Table 1.
    Table 1 Parameters for accessing an image repository
    Example Value
    Jump Cluster
    Select the cluster that carries the image repository.
    cluster01
    Scan Component Source
    The image scan component is used to pull images, scan and analyze required metadata, and transmit the metadata to the server. The server performs security detection on the metadata, such as vulnerabilities, baselines, malicious files, and sensitive information.
    The image scan component needs to be uploaded to the image repository. You can obtain the image scan component in either of the following ways:
    • SWR: The cluster can communicate with SWR and obtain image scan components from SWR.
    • Manually uploaded: If the network between the cluster and SWR is disconnected, you need to manually upload the image scan component to the image repository.
    SWR
    Image Repository Name
    Enter the full name of an image repository.
    test
    Image Repository Type
    Click and select the type of the image repository.
    Harbor
    Image Repository API Version
    Click and select the interface version of the image repository.
    V1
    Image Repository Project
    If you select Manually uploaded and the image repository type is Harbor, you need to enter image repository project information.
    Communication Type
    Select the communication protocol type of the image repository.
    • HTTP
    • HTTPS
    HTTPS
    Image Repository Address
    Enter the image repository address.
    You can enter the website address or IP address:port number of the image repository.
    Example: myharbor.com
    myharbor.com
    Username
    Enter the login username.
    Password
    Enter the password of the login user.
  8. (Optional) If you select Manually uploaded for the scan component, perform the following operations to configure the scan components after entering the access information:
    1. In the Connect to Third-Party Image Repository dialog box, click Generate Command.
    2. In the Connect to Third-party Image Repository dialog box, click Copy the image pull command.
    3. Log in to any Linux server that can access the Internet, paste and run the command copied in 8.b to download the scan component image.
    4. Copy the downloaded scan component image to any node in the repository cluster.
    5. In the Connect to Third-party Image Repository dialog box, click Copy the following command. Run the copied command on the cluster node where the scan component is located. The scan component will be uploaded to the image repository.
    6. If the information shown in Figure 1 is displayed, the scan component is uploaded successfully.
      Figure 1 Scan component uploaded
  9. Click OK to connect to the image repository.
  10. On the Third-party Image Repositories tab page, view the access result in the Image Repository Status column of the target image repository.
