Installing the Agent in a CCE Cluster
Install the agent in a CCE cluster. After the configuration is complete, HSS automatically installs the agent on existing cluster nodes, installs the agent on new nodes when the cluster is scaled out, and uninstalls the agent from removed nodes when the cluster is scaled in.
Before installing an agent for a CCE cluster, grant the CCEOperatePolicy permission to HSS. For details, see Authorization.
- Supported container runtime: Docker and Containerd
- Supported cluster editions: CCE standard and Turbo editions
- Node resource requirements: At least 50 MiB memory and 200m CPU should be available.
- When an agent is installed in a cluster, HSS creates an HSS namespace in the cluster.
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose .
- On the Cluster tab page, click Install Container Agent. The Container Asset Access and Installation slide-out panel is displayed.
- Select CCE Cluster Installation and click Configure Now.
- Select a cluster and click Next.
- Configure agent parameters. For more information, see Table 1.
Table 1 Agent parameters Parameter
Configuration Rules
Select an agent configuration rule.
- Default Rule: Select this if the sock address of container runtime is a common address. The agent will be installed on nodes having no taints.
- Custom: Select this rule if the sock address of your container runtime is not a common address or needs to be modified, or if you only want to install the agent on specific nodes.
NOTE:- If the sock address of your container runtime is incorrect, some HSS functions may be unavailable after the cluster is connected to HSS.
- You are advised to select all runtime types.
(Optional) Advanced Configuration
This parameter can be set if Custom is selected for Configuration Rules.
Click
to expand advanced configurations. The Enabling auto upgrade agent option is selected by default.
- Enabling auto upgrade
Configure whether to enable automatic agent upgrade. If it is enabled, HSS automatically upgrades the agent to the latest version between 00:00 to 06:00 every day to provide you with better services.
- Node Selector Configuration
Set the Key and Value of tags of the nodes where the agent is to be installed and click Add. If no tags are specified, the agent will be installed on all the nodes having no taints.
- Tolerance Configuration
If you added a node whose tag contains a taint in Node Selector Configuration, set the Key, Value, and Effect of the taint, and click Add to allow agent installation on the node.
- Click OK to start installing the HSS agent.
- In the cluster list, check the cluster status. If the cluster status is Running, the cluster is successfully connected to HSS.
Follow-up Procedure
After the agent is installed in a cluster, enable protection.
