Upgrading or Uninstalling the Agent from an Independent Node
You can upgrade the agent or uninstall it from an independent node.
The agent of a node is online.
Upgrading the Agent on an Independent Node
HSS is periodically updated to improve its capabilities. You are advised to upgrade the agent to the latest version in a timely manner.
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose .
- Click the Non-cluster Node tab.
- Upgrade the agent using either of the following methods:
- Automatic upgrade
In the upper right corner of the node list, click
to enable automatic upgrade. After this function is enabled, HSS automatically upgrades all agents to the latest version between 00:00 and 06:00 every day. You can view the agent version of a node after 06:00 the next day to check whether the upgrade is successful.
- Manual upgrade
- In the Operation column of a cluster, click Upgrade Agent.
To upgrade the agent on CCE clusters in batches, select all target nodes and click Upgrade Agent.
- Confirm the upgrade information and click OK.
Wait for 5 to 10 minutes. If the agent version of the target node is the latest, the upgrade is successful.
- Automatic upgrade
Uninstall the HSS agent if you no longer need it. This section describes how to uninstall an online agent. If the agent status is offline, perform the operations in Manually Uninstalling the Agent from a Server.
- Click
and choose .
- In the Operation column of a node, click Uninstall Agent.
To uninstall the agent from nodes in batches, select all target nodes and click Uninstall Agent.
- Confirm the uninstallation information and click OK.
Wait for 5 to 10 minutes. If the agent status of the target node is Not installed, the uninstallation is successful.
