Upgrading or Uninstalling the Agent from a Cluster
You can upgrade the agent or uninstall it from a cluster.
The cluster is running.
Upgrading the Cluster Agent
HSS is periodically updated to improve its capabilities. You are advised to upgrade the agent to the latest version in a timely manner.
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - In the navigation pane, choose .
- Click the Cluster tab.
- In the Operation column of a cluster, click Upgrade Agent.
To upgrade the agent on CCE clusters in batches, select all target CCE clusters and click Upgrade Agent.
- Confirm the upgrade information and click OK.
Wait for 5 to 10 minutes. If the agent version in the cluster list is the latest and the Upgrade Agent button is grayed out, the upgrade is successful.
- Click
- In the Operation column of a cluster, click Uninstall Cluster.
To uninstall CCE clusters in batches, select all target clusters and click Uninstall Agent. Clusters of other types cannot be uninstalled in batches.
- Confirm the uninstallation information and click OK.
Wait for 5 to 10 minutes. If the cluster is not displayed in the cluster list, the agent has been uninstalled.
