Help Center/
Host Security Service/
User Guide (Kuala Lumpur Region)/
Server Protection/
Dynamic Port Honeypot/
Managing Dynamic Port Honeypot Protection Policies
Updated on 2025-10-10 GMT+08:00
After a policy is created, you can manage the policy based on your protection requirements.
- Disabling a policy: Disable the dynamic port honeypot function temporarily.
- Enabling a policy: Re-enable the disabled dynamic port honeypot policy.
- Editing a policy: Modify the protection policy information of dynamic port honeypot, for example, adding or deleting ports, and unbinding or binding servers.
- Deleting a policy: Delete the dynamic port honeypot protection policy and disable the function.
The default policy cannot be deleted.
Disabling a Policy
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- Choose Server Protection > Dynamic Port Honeypot.
- (Optional) If you have enabled the enterprise project, select the enterprise project where the target server resides from the drop-down list.
- In the row containing the target policy, click Disable Policy in the Operation column. The dialog box is displayed.
- Confirm the information and click OK.
Enabling a Policy
- Click
and choose .
- In the row containing the target policy, click Enable Policy in the Operation column. The dialog box is displayed.
Editing a Policy
- Click
and choose .
- In the row containing the target policy, click Edit Policy in the Operation column. The dialog box is displayed.
- Configure a policy.
You can modify the policy name, protected port, and source IP address whitelist.
- Click Next.
- Select a server to be bound.
- Click OK.
Delete a Policy
- Click
and choose .
- In the row containing the target policy, click Delete in the Operation column. The Delete Policy dialog box is displayed.
- Ensure that all information is correct and click OK.
Parent topic: Dynamic Port Honeypot
