Updated on 2025-10-10 GMT+08:00
Viewing and Handling Honeypot Protection Events
By default, the servers that proactively connect to the dynamic honeypot port are compromised intranet servers. Once a suspicious connection behavior is detected, a honeypot protection event will be reported. The event contains the server IP address that initiates the connection, but does not contain process details. You can check for and locate compromised servers based on honeypot protection and other event.
This section describes how to view and handle honeypot protection events.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. Choose Server Protection > Dynamic Port Honeypot.
  5. Under the introductions, view the protection overview.
    • You can view the number of protection policies, protected servers, and protection events.
    • You can enable the Automatically apply default policies to newly add servers. If is displayed, the function is enabled.
  6. Click the Protection Events tab to view honeypot protection events. For details about the parameters in the event list, see Table 1.
    Table 1 Parameters in the event list
    Alarm Name
    The name of an alarm event. Click an alarm name to view the details. For details, see Table 3.
    Alert Severity
    Alarm threat level. Honeypot protection events are classified into the following two levels:
    • High risk: The remote server connects to the honeypot port for multiple times.
    • Medium risk: The remote server is connected to the honeypot port.
    Alarm Summary
    Summary of alarm events. Based on the information, you can learn about the server that may have been compromised and the connection between the server and the port.
    Affected Asset
    Dynamic port server connected to the server that may have been compromised.
    Alarm Reported
    Time when an alarm occurred.
    Status
    Alarm handling status, which can be Handled or To be handled.
  7. After confirming the alarm information, click Handle in the Operation column of the event whose Status is To be handled. The Handle Alarm dialog box is displayed.
    If you need to handle multiple alarm events in batches, click Batch Handle in the upper left corner of the list.
  8. Select a solution. For details about the solution, see Table 2.
    Table 2 Parameters for handling alarm events
    Action
    • Ignore: Ignore the alarm event. The alarm is still generated when the next threat event occurs.
    • Mark as handled: You can manually isolate ports for the compromised server.
    • Add to alarm whitelist: Add the trusted server that triggers an alarm to the whitelist so that no alarm will be generated when similar events occur.
    Batch Handle
    If you need to handle the same alarm event at the same time, you can select the parameter.
    (Optional) Remarks
    To facilitate identification of the current processing, supplementary description can be provided.
  9. Click OK.
Alarm Details Parameters
For details about the parameters on the alarm details, see Table 3.
Table 3 Alarm details parameters
Intelligence Engine
Detection engines used by HSS, including the virus detection engine, AI detection engine, and malicious intelligence detection engine.
Attack Status
Status of the current threat.
First Occurred
Time when an alarm was generated for the first time.
Alarm ID
Unique ID of an alarm
ATT&CK Phase
Attack model used by attackers in each phase.
Last Occurred
Time when an alarm was generated for the last time.
Alarm Information
Detailed information about an alarm, including the alarm description, alarm summary, affected assets, and handling suggestions.
Forensics
The dynamic port honeypot function checks the network forensics information of the attack source.
Similar Alarms
Alarms that are similar to the current alarm event. You can handle the alarm according to the handling method of the similar alarms.
Filtering Events in Different Handling Statuses
Select an event in the target status from the drop-down list.
