Updated on 2025-10-10 GMT+08:00
Exporting a Baseline Check Report
Yon can export the baseline check results to your local PC.
Only the HSS enterprise, premium, WTP, and container editions support baseline configuration checks.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane on the left, choose Prediction > Baseline Checks.
  5. Perform the following operations to export the detection result based on the baseline check type:
    • Unsafe configurations
      Click the Unsafe Configurations tab, and click Export in the upper left corner of the list. In the displayed dialog box, set the export scope and click OK to export the configuration check results.
    • Password complexity policies
      Click the Password Complexity Policy Detection tab. In the upper left corner of the list, click Export > Export all data to an XLSX file to export the result.
    • Common weak passwords
      Click the Common Weak Password Detection tab. In the upper right corner of the list, click to export the result.
      You can enter the server name, IP address, or account name in the upper right corner of the list, and click to search for the target content and download it.
