Help Center/ Host Security Service/ User Guide (Kuala Lumpur Region)/ FAQs/ Detection & Response/ How Do I Add High-risk Command Execution Alarms to the Whitelist?
Updated on 2025-10-10 GMT+08:00
If you run commands related to normal services on the server, HSS generates high-risk command execution alarms. You can add a whitelist to prevent the alarm.
To add a command alarm whitelist, perform the following steps:
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane, choose Security Operations > Policies.
  5. Locate the policy group of the protected edition corresponding to the server and click the policy group name.
  6. Click Real-time Process.
  7. Add a command whitelist. The parameters are as follows:
    • Full path or program name of a process: Enter the full path or program name of the process, for example, /usr/bin/sleep or sleep.
    • Regular expression in CLI: Enter the regular expression of the command to be added to the whitelist, for example, ^[A-Za-z0-9[:space:]\\*\\.\\\":_'\\(>=-]+$.
  8. Click OK to save the change.
