Restoring Server Data
If ransomware backup is enabled for a server, and the server is intruded by ransomware, you can use the backup to restore the server data and minimize losses. Before using the backup for server restoration, check whether the backup is normal. If it is, use it to restore service-critical systems first.
The backup function has been enabled. For details, see Enabling Backup.
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Server Protection > Ransomware Prevention. Click the Protected Servers tab. In the Operation column of a server, click Restore Data.
- In the displayed dialog box, view the information about the target server. Search for the backup data source to be restored by backup status and backup name. For details about the parameters, see Table 1.
Table 1 Backup data source parameters Parameter
Example Value
Backup Name
Name of a backup file.
Status
Backup status. It can be:
- Available: The backup data source is normal and can be used for restoration.
- Creating: The backup is being created.
- Deleting: The backup is being deleted.
- Restoring: The backup is being used for restoration.
- Error: Backup error.
Available
Purpose
Backup purpose. It can be:
- Periodic execution: Data is automatically backed up based on the backup period configured in the backup policy.
- Ransomware protection: Data is backed up immediately when a server is attacked by ransomware.
Periodic execution
Execution Time
Time when the data source was backed up.
- In the Operation column of a backup, click Restore Data.
- In the displayed dialog box, confirm the server information and click OK.
- In the Backup Statistics column, click the value of Backup and Restoration Task to view the backup and restoration progress.
Related Operations
Deleting a backup
You can delete the backup data of a server if it is no longer required. A deleted backup cannot be restored. Exercise caution when performing this operation.
- In the Backups column of a server, click the number. The backup list is displayed.
- In the Operation column of a backup, click Delete. The backup deletion dialog box is displayed.
- Confirm the backup information and click OK.
