Exporting the Vulnerability List
You can refer to this section to export the vulnerability list.
Prerequisite
The Server Status is Running, Agent Status is Online, and Protection Status is Protected. For details, see Viewing Server Protection Status.
Exporting the Vulnerability List (Server View)
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Prediction > Vulnerabilities.
- In the upper left corner of the Vulnerabilities page, click the Server view tab.
- Export the vulnerability list.
- Export vulnerability details: In the upper part of the vulnerability list, click Export Details to export the vulnerability list.
You can select the risk level, vulnerability handling status, or search criteria to filter the vulnerability information of the target server, and click Export Details to export the vulnerability details.
- Export a vulnerability report: In the upper part of the vulnerability list, click Export Report and select a report format.
- When exporting a vulnerability report in HTML format, the vulnerability information about up to 100 servers can be exported. In the exported HTML vulnerability report, you can view vulnerability details.
- When exporting a vulnerability report in PDF format, the vulnerability information about up to 140 servers and vulnerabilities can be exported.
- To export vulnerability reports of some servers, you can select the servers and click Export.
- View the export status in the upper part of the Vulnerabilities page. After the export is successful, obtain the exported information from the default file download address on the local host.
Do not close the browser page during the export. Otherwise, the export task will be interrupted.
