Updated on 2025-10-10 GMT+08:00
Configuring Common Login Locations
After you configure common login locations, HSS will generate alarms on the logins from other login locations. A server can be added to multiple login locations.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. Choose Installation & Configuration > Server Install & Config and click the Security Configuration tab. Click Common Login Locations and click Add Common Login Location.
  5. In the dialog box that is displayed, select a geographical location and select servers. Confirm the information and click OK.
  6. Return to the Common Login Locations sub-tab and check the added common login locations. If they are displayed, the addition succeeded.
