Updated on 2025-10-10 GMT+08:00
Enabling Backup
So far, no tools can defend against all ransomware. You can enable backup for servers, so that their data can be restored in a timely manner in the case of a ransomware attack.
Ransomware backup can be performed in two modes: scheduled backup and immediate backup upon ransomware detection. You can create a custom scheduled backup policy to periodically back up servers. If HSS detects a suspected ransomware attack, it will immediately trigger a backup to ensure service data is stored as much as possible.
This section describes how to enable ransomware backup.
(Optional) Step 1: Purchasing a Backup Vault
You can purchase a backup vault on the HSS console by referring to this section, or on the CBR console.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. Choose Server Protection > Ransomware Prevention.
  5. Toggle on ransomware backup. In the dialog box that is displayed, click Next.
  6. In the displayed dialog box, set the vault parameters.
    Table 1 Parameters for purchasing backup capacity
    Billing Mode
    The default billing mode is pay-per-use. You pay for the duration you use the resources. Prices are calculated by hour, and no minimum fee is required.
    Region
    Region of the backup vault you want to purchase
    Capacity
    Select the size of the backup vault as required.
    Price
    Fees are generated by default based on the backup capacity.
  7. Click OK.
Step 2: Enabling Ransomware Backup
  5. Click the Protected Servers tab.
  6. Select a server and click Enable Backup.
  7. In the Enable Backup dialog box, select a vault.
    A vault that meets the following conditions can be bound:
    • The vault is in Available or Locked state.
    • The backup policy is in Enabled state.
    • The vault has backup capacity available.
    • The vault is bound to fewer than 256 servers.
  8. Click OK.
    If the binding status of the repository on the target server is Bound, the ransomware backup is enabled.
Related Operations
Ransomware backup can only be used to restore data after a ransomware attack to reduce some losses. To detect and defend against ransomware attacks in real time, enable ransomware prevention. For details, see Enabling Ransomware Prevention.
