Help Center/
Host Security Service/
User Guide (Kuala Lumpur Region)/
Asset Management/
Container Management/
Uninstalling the Agent from a Cluster
Updated on 2025-10-10 GMT+08:00
Uninstalling an Agent from a CCE Cluster
- Log in to the CCE console.
- In the upper left corner of the page, select a region, click
, and choose . The CCE console is displayed.
- Click the name of a cluster to enter its details page.
- In the navigation pane, choose Workloads.
- Click the DaemonSets tab. Delete the workload install-agent-ds.
In the Operation column of the workload, choose
. - Click
in the upper left corner of the page, select a region, and choose Security > Host Security Service. The HSS page is displayed.
- Click
in the upper left corner and select a region or project.
- In the navigation tree on the left, choose Installation & Configuration > Server Install & Config.
- Click the Agents tab. Uninstall the agent from all container nodes in the CCE cluster.
For details, see Uninstalling the Agent.
Uninstalling an Agent from an On-Premises Cluster
- Log in to the Kubernetes cluster.
- Run the following command to delete the workload install-agent-ds:
kubectl delete ds install-agent-ds -n default
- Click
- In the upper left corner of the page, click
and choose .
- Click the Agents tab. Uninstall the agent from all container nodes in the cluster.
Parent topic: Container Management
