Help Center/ Host Security Service/ User Guide (Kuala Lumpur Region)/ FAQs/ Container Security/ What Do I Do If the Container Cluster Protection Plug-in Fails to Be Uninstalled?
Updated on 2025-10-10 GMT+08:00
Possible Causes
If the cluster network is abnormal or the plug-in is running, uninstalling the plug-in on the HSS console may fail.
Solution
On a cluster node where you can use kubectl to access the API Server, perform the following operations to uninstall the cluster protection plug-in:
  1. Log in to a cluster node where you can use kubectl to access the API Server.
  2. Create the file plugin.yaml in the /tmp directory and copy the following script content to the file:
      3
      4
      5
      6
      7
      8
      9
     10
     11
     12
     13
     14
     15
     16
     17
     18
     19
     20
     21
     22
     23
     24
     25
     26
     27
     28
     29
     30
     31
     32
     33
     34
     35
     36
     37
     38
     39
     40
     41
     42
     43
     44
     45
     46
     47
     48
     49
     50
     51
     52
     53
     54
     55
     56
     57
     58
     59
     60
     61
     62
     63
     64
     65
     66
     67
     68
     69
     70
     71
     72
     73
     74
     75
     76
     77
     78
     79
     80
     81
     82
     83
     84
     85
     86
     87
     88
     89
     90
     91
     92
     93
     94
     95
     96
     97
     98
     99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    apiVersion: v1
    kind: Namespace
      labels:
        admission.gatekeeper.sh/ignore: no-self-managing
        control-plane: controller-manager
        gatekeeper.sh/system: "yes"
        pod-security.kubernetes.io/audit: restricted
        pod-security.kubernetes.io/audit-version: latest
        pod-security.kubernetes.io/enforce: restricted
        pod-security.kubernetes.io/enforce-version: v1.24
        pod-security.kubernetes.io/warn: restricted
        pod-security.kubernetes.io/warn-version: latest
    apiVersion: apiextensions.k8s.io/v1
    kind: CustomResourceDefinition
      annotations:
        controller-gen.kubebuilder.io/version: v0.10.0
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
        controller-gen.kubebuilder.io/version: v0.11.3
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
      annotations:
      labels:
    kind: Role
      creationTimestamp: null
      labels:
      namespace: gatekeeper-system
    kind: ClusterRole
      labels:
    kind: RoleBinding
      labels:
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    subjects:
    - kind: ServiceAccount
    kind: ClusterRoleBinding
      labels:
    roleRef:
      kind: ClusterRole
    subjects:
    apiVersion: admissionregistration.k8s.io/v1
    kind: MutatingWebhookConfiguration
      labels:
    kind: ValidatingWebhookConfiguration
      labels:
  1. Create the file uninstall.sh in the /tmp directory and copy the following script content to the file:
    3
    #!/bin/bash
    kubectl delete -f /tmp/plugin.yaml
    kubectl delete ns cgs-provider
  2. Run the following command to uninstall the container cluster protection plug-in:
    bash /tmp/uninstall.sh
    If information similar to the following is displayed, the plug-in has been uninstalled.
