Exporting Container Alarms
You can export container alarms and events to a local PC.
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - In the navigation pane, choose Detection & Response > Alarms.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click the Container Alarms tab.
- Click Export above the alarm list to export all security events.
To export the alarms of a certain type or ATT&CK attack phase, select the type or phase in the Alarms to Be Handled area and click to export.
- View the export status in the upper part of the alarms page. After the export is successful, obtain the exported information from the default file download address on the local host.
Do not close the browser page during the export. Otherwise, the export task will be interrupted.
