Updated on 2025-10-10 GMT+08:00
Disabling Application Process Control
You can disable application process control for one or multiple servers at a time.
Disabling Protection for Servers Associated with a Policy
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  1. In the navigation tree, choose Server Protection > Application Process Control.
  1. Click the Whitelist Policies tab.
  2. Disable application process control.
    • Disable protection but retain the application process characteristics learned by HSS.
      1. In the Operation column of a policy, click Disable Protection. Alternatively, select multiple policies and click Disable above the policy list.
      2. Click OK.
    • Disable protection and delete the application process characteristics learned by HSS.
      1. In the row of a policy, click Delete in the Operation column.
      2. Click OK.
  3. Check the policy list.
      If the Policy Status of the policy is Learning complete but not in effect, application process control has been disabled.
      If the policy is deleted from the policy list, application process control has been disabled.
Disabling Protection for a Single Server
  2. Click a policy name. The Policy Details page is displayed.
  3. Click the Associated Servers tab.
  4. Disable application process control.
    • Disable protection but retain the association between the server and the policy.
      2. Click OK.
    • Disable protection and disassociate the server from the policy.
      To change the protection policy associated with a server, remove the server from the policy settings, and then create or edit another protection policy to associate with the server.
      1. In the row containing the desired instance, click Delete in the Operation column.
      2. Click OK.
  5. Check the server list.
      If the Policy Status of the server is Learning complete but not in effect, application process control has been disabled.
      If the server is deleted from the list, application process control has been disabled.
