Authorization
Some HSS functions depend on other cloud service resources. To use these functions, you need to delegate HSS to perform operations on related cloud service resources, such as task scheduling and resource O&M.
Table 1 describes the cloud service resource permissions that HSS needs you to assign.
Function |
Required Permission |
Cloud Service Permission |
Usage |
Permission |
Action |
Container audit (image repository audit) |
CTSOperatePolicy |
Query audit events |
cts:trace:list |
Obtain image operation logs (CTS logs of SWR). |
Installation and configuration on servers |
VPCOperatePolicy |
Create a port |
vpc:ports:create |
Create network interface cards (NICs) and modify security groups to ensure that the port used for installing the agent is accessible. |
Delete a port |
vpc:ports:delete |
Create a security group rule |
vpc:securityGroupRules:create |
Delete a security group rule |
vpc:securityGroupRules:delete |
Query the port list or the details about a port |
vpc:ports:get |
Query the network list or the details about a network |
vpc:networks:get |
Query the subnet list or the details about a subnet |
vpc:subnets:get |
VPCEPOperatePolicy |
Create an endpoint |
vpcep:endpoints:create |
Maintain the network channel between the agent and the HSS cloud protection center (master). |
Query the endpoint list |
vpcep:endpoints:list |
Delete an endpoint |
vpcep:endpoints:delete |
Installation and configuration on containers |
CCEOperatePolicy |
Query cluster information |
cce:cluster:get |
Manage the lifecycle of HSS-Daemonset and Configmap in a CCE cluster. |
Query clusters in a project |
cce:cluster:list |
Query agencies based on specified conditions |
iam:agencies:listAgencies |
Assigning Cloud Service Resource Permissions
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Installation & Configuration > Permissions Management.
- Click Assign. The Assign dialog box is displayed.
- Select permissions and click OK.
Deleting Cloud Service Resource Permissions
- Click
and choose . - In the navigation pane, choose Installation & Configuration > Permissions Management.
- Locate a permission and click Remove in the Operation column. The Remove Permissions dialog box is displayed.
Alternatively, select multiple permissions and click Remove above the list.
- Confirm the permission information, enter DELETE in the dialog box, and click OK.
If the permission is no longer displayed in the permission list, it indicates the permission has been removed.
