Updated on 2025-10-10 GMT+08:00
Configuring a Container Cluster Protection Policy
You can configure container cluster protection policies to specify the level of risks (unsafe baselines, vulnerabilities, or malicious files) that trigger alarms, cluster protection scope, image whitelist, and the actions taken on an alarm.
Creating a Protection Policy
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  1. In the navigation pane, choose > Container Cluster Protection.
  2. Click the Protection Policies tab and click Create Policy.
  3. In the Create Policy dialog box, set policy parameters. For details about related parameters, see Table 1.
    Table 1 Container cluster protection policy parameters
    Example Value
    Policy Template
    Select a policy template. The procedure is as follows:
    1. Click Select Template.
    2. Select a policy template and click OK.
      You can select a policy template based on the policy description.
    After selecting a policy template, configure policy parameters based on the policy template requirements. You can refer to the parameter description.
    K8sPSPPrivilegedContainer
    Policy Name
    Enter a policy name. The name can only contain letters, numbers, commas (,), periods (.), spaces, underscores (_), and hyphens (-).
    test
    Policy Description
    Enter policy description. The description can only contain letters, numbers, commas (,), periods (.), spaces, underscores (_), and hyphens (-).
    Test
    Action
    Action taken by HSS if it detects that an image to be started contains specified unsafe baseline items, vulnerabilities, or malicious scripts.
    • Alarm: Generate an event whose Action is Alarm on the Protection Events tab of the Container Cluster Protection page.
    • Block: Block an unsafe image and generate an event whose Action is Block on the Protection Events tab of the Container Cluster Protection page.
    • Allow: Generate an event whose Action is Allow on the Protection Events tab of the Container Cluster Protection page.
    Block
    Protection Scope
    Configure the protection scope of clusters.
    If you select the image blocking policy, you need to set the images and tags to specify the protection scope.
    (Optional) Whitelist
    Images to be added to the whitelist. HSS does not check whitelisted images when they are started.
    Enter values in ImageName:ImageVersion format. An image name can contain only numbers, letters, underscores (_), hyphens (-), and periods (.). Each image name occupies a separate line.
    Example:
    • A single image
      image:1.0
    • Multiple images
      image1:1.0
      image2:1.0
  4. Click OK.
    You can view the protection policy in the policy list.
Editing or Deleting a Cluster Protection Policy
  1. Choose Container Cluster Protection and click the Protection Policies tab.
  2. In the Operation column of a policy, click a button as required.
    • View YAML: View the protection policy content in YAML format.
    • Edit: Modify a protection policy.
    • Delete: Delete a protection policy. After a policy is deleted, the container clusters associated with it will no be protected. Exercise caution when performing this operation.
  3. Click OK.
