Updated on 2025-10-10 GMT+08:00
Viewing Plug-in Information
The plug-in configuration page displays the server list and the plug-in information of the servers. If no plug-ins are installed on a server, the corresponding plug-in information is empty. You can view the plug-in information of a server to determine the servers where plug-ins need to be installed.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. In the navigation pane on the left, choose Installation & Configuration > Plug-in Settings.View plug-in details on the plug-in settings page. For more information, see Table 1.
    By default, all servers are displayed in the plug-in list. If a plug-in is installed on a server, the plug-in details are displayed. If no plug-ins are installed on a server, the plug-in information is empty.
    Table 1 Docker plug-in list parameters
    Server Name/ID
    Server name and ID
    IP Address
    Server IP address
    OS
    Type of the OS running on the server
    Plug-in Name
    Name of the plug-in installed on the server.
    Plug-in Version
    Plug-in Status
    Current status of the plug-in.
    • Created: The plug-in has been created but has not been started.
    • Running: The plug-in is running properly.
    • Paused: The plug-in is paused.
    • Restarting: The plug-in is being restarted.
    • Removing: The plug-in is being deleted.
    • Exited: The plug-in has been stopped.
    • Dead: The plug-in cannot be started or has been deleted.
    Plug-in Upgrade Status
    Plug-in upgrade status.
    • Not upgraded: The plug-in has not been upgraded to the latest version.
    • Upgrading: The plug-in is being upgraded.
    • Upgraded: The plug-in has been upgraded.
    • Upgrade failed: The plug-in failed to be upgraded.
