Managing Application Protection Policies
Application protection policies can be added, edited, and deleted in the following scenarios:
- Addition: HSS provides a default policy, which contains all the rules for application protection. If you need to customize the policy for a server, you can add a protection policy and customize the rules and configurations in the policy.
- Editing: You can edit a custom protection policy.
- Deletion: You can delete a custom protection policy that is not associated with any server.
Adding a Policy
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 1.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click Add Policy. In the dialog box that is displayed, configure the parameters by referring to Table 2.
Table 2 Application protection policy parameters Parameter
Policy Name
User-defined policy name
Enabled
Whether to enable a rule for the current policy. You can select rules to enable them as required.
Detection Rule ID
ID of a rule.
Action
Action of a rule.
- Detect: Detects objects based on the target rule and reports alarms for detected risk events.
- Detect and block: Detects objects based on the target rule, reports alarms for detected risk events, and directly blocks or intercepts detected risk items.
WARNING:
Blocking or interception may interrupt services. Exercise caution when enabling this function.
Description about the detected object and behavior of the target protection policy.
- Click Configure in the Operation column of a rule to modify the rule content. Table 3 describes the supported rules.
Table 3 Detection rules that can be configured only Rule
Example
XXE
User-defined XXE blacklist protocol
.xml;.dtd;
XSS
User-defined XSS shielding rules
xml;doctype;xmlns;import;entity
WebShellUpload
User-defined suffix of files in the blacklist.
.jspx;.jsp;.jar;.phtml;.asp;.php;.ascx;.ashx;.cer
FileDirAccess
User-defined path of files in the blacklist.
/etc/passwd;/etc/shadow;/etc/gshadow;
- Confirm the configured policy and selected detection rules, and click OK. You can check whether the rule is added on the Protection Policy tab page.
Editing a Policy
- Click
and choose .
- Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 4.
- Click Edit in the Operation column of a policy to configure the policy name, supported rules, and rule content.
Table 5 Application protection policy parameters Parameter
Policy Name
Enabled
Detection Rule ID
ID of a rule.
Action
Action of a rule.
NOTICE:
- Confirm the rule settings and check items, and click OK. You can check whether the rule has been modified on the Policies page.
Deleting a Policy
- Click
and choose .
- Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 6.
- Click Delete in the Operation column of a policy. In the dialog box that is displayed, confirm the policy information and click OK.
Only the policies that are not associated with any server can be deleted.
