Enabling Container Protection
The HSS container edition protects containers throughout their lifecycles. This section describes how to enable protection for container nodes.
- Ensure that the agent has been installed on the container node and is online. For details about how to install the agent on a single node, see Installing the Agent on Cloud Platform Servers. For details about how to install the agent on a cluster, see Installing the Agent on Containers.
HSS can only protect Docker, Containerd, CRI-O, Podman, and iSulad containers.
Enabling the Container Edition
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane, choose Asset Management > Containers & Quota.
- In the row of a server, click Enable Protection in the Operation column. The confirmation dialog box is displayed.
- Confirm the node information and select a billing mode.
- Read the Host Security Service Disclaimer and select I have read and agree to the Container Guard Service Disclaimer.
- Click OK. If the Protection Status of the node changes to Protected, protection has been enabled.
- (Optional) Configure alarm notification, protection policies, server login protection, and malicious program isolation and removal.
- Configuring alarm notifications
After HSS is enabled, alarms are displayed on the console by default. To learn the security risks of servers, containers, or web pages in a timely manner, you can enable alarm notification, and HSS will notify you of risks by SMS or email. For details, see Alarm Configuration.
- Configuring protection policies
Each HSS edition provides a group of protection policies preset with default settings. You can enable or disable policies and adjust protection rules as needed. For details, see Policy Management.
- Configuring login protection
To enhance server login security, perform the operations in Enabling 2FA, Configuring Common Login Locations, Configuring Common Login IP Addresses, and Configuring an SSH Login IP Address Whitelist.
- Enabling malicious program isolation and removal
If this function is enabled, HSS will automatically isolate identified malicious programs, such as backdoors, Trojans, and worms, to help you handle security risks. For details, see Isolating and Killing Malicious Programs.
Viewing Scan Details
After server protection is enabled, HSS will immediately perform a comprehensive scan on the server. It may take a long time. After the scan is complete, you can check its details.
- Choose Servers tab page. . Locate the server on the
- Check the Risk Level column of the server.
Table 1 Risk status Status
Pending risk detection
The server is neither protected nor scanned.
Safe
No risks were found in the comprehensive scan on the server; or the protection has just been enabled, and no risks have been found yet.
Risky
The server has security risks.
- Hover the cursor over the risk status to view the risk distribution.
You can click a value to go to the details page.
Advanced protection
HSS provides a series of advanced defense functions. You can enable or use them as required to enhance the security of your servers and containers. For details, see Table 2.
Function |
Description |
To protect your applications with RASP, you simply need to add probes to them, without having to modify application files. |
The function can detect and defend against ransomware. It can automatically back up data either at a scheduled time, or immediately if ransomware is detected. This can help you defend against ransomware and reduce loss. Ransomware prevention is automatically enabled with the container edition. HSS will deploy honeypot files on servers and automatically isolate suspicious encryption processes. You can modify the ransomware protection policy. |
Application process control helps to enhance the security of applications and processes running on servers. It can automatically identify and analyze application processes, and classify them into trusted, suspicious, and malicious processes. It allows trusted processes to run, and generates alarms for suspicious and malicious processes. This helps to build a secure environment for application processes, and protects servers from untrusted or malicious application processes. |
This function combines cloud-based and local antivirus mechanisms to scan executable files, compressed files, scripts, documents, images, and audiovisual files for viruses. You can perform quick scan, full-disk scan, and custom scans on servers as needed to detect and remove virus files in a timely manner, enhancing the virus defense of the system. |
The dynamic port honeypot function is a proactive defense measure. It uses a real port as a honeypot port to induce attackers to access the network. In the horizontal penetration scenario, the function can effectively detect attackers' scanning, identify faulty servers, and protect real resources of the user. |
The container firewall can isolate pods, workloads, and nodes in a network to prevent lateral movement and minimize permissions, and enhancing security and stability. |
HSS can check for non-compliance baseline issues, vulnerabilities, and malicious files when a container image is started and report alarms on or block container startup that has not been unauthorized or may incur high risks. |
