Updated on 2025-10-10 GMT+08:00
Disabling Application Protection
You can disable application protection if it is no longer needed.
  2. Click in the upper left corner and select a region or project.
  3. In the upper left corner of the page, click and choose Security > Host Security Service.
  4. Choose Server Protection > Application Protection. Click the Protected Servers tab.
  5. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  6. Toggle off the switch in the RASP Protection column or click Disable Protection in the Operation column.
  7. In the dialog box that is displayed, confirm the server information and click OK.
    After RASP is disabled for a server, the server will be removed from the Protected Servers tab. For details about how to enable protection, see Enabling Application Protection.
