Viewing Application Protection
After application protection is enabled, you can view the protection status and events on the Application Protection page. You can analyze the events and harden your applications accordingly.
Checking the Protection Status
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- Choose Server Protection > Application Protection. Click the Protected Servers tab.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- View the service protection status. For details, see Table 1.
Table 1 Parameters for protection settings Parameter
Server Name/ID
Server name and ID
IP Address
Private IP address and EIP of the server
OS
Server OS
Server Group
Group that the server belongs to
Policy
Detection policies bound to the target server.
Protection Status
Agent status of a server.
- Protected: The agent is online.
- Unprotected: The agent is offline.
Microservice Protection
Microservice protection status. Its value can be:
- Effective: The microservice protection is enabled successfully.
- Installing: The microservice RASP protection software is being installed and protection is disabled.
- Installed but not configured: The microservice RASP protection software is successfully installed, but microservice startup parameters are not configured and protection is disabled.
- Installation failed: The microservice RASP protection software fails to be installed.
RASP Protection.
RASP protection status. Its value can be:
If the following information is displayed, protection is not enabled. Check whether there are operations that are not handled by referring to Enabling Application Protection.
Detected Attacks
Number of attacks detected by RASP.
Viewing Events
- Click
and choose .
- Choose Server Protection > Application Protection and click the Events tab. For more information, see Table 2.
To view the events of a server, click View Report in the Operation column of the server.
Table 2 Event parameters Parameter
Severity
Alarm severity. You can search for servers by alarm severities.
- Critical
- High
- Medium
- Low
Server Name
Server that triggers an alarm
Alarm Name
Alarm name
Alarm Time
Time when an alarm is reported
Attack Source IP Address
IP address of the server that triggers the alarm
Attack Source URL
URL of the server that triggers the alarm
- You can click an alarm name to view the attack information (such as the request information and attack source IP address) and extended information (such as detection rule ID and description), and troubleshoot the problem accordingly.
