Servers Importance Management
By default, HSS considers all servers as general assets. You can configure the asset importance levels of servers and manage servers accordingly.
- Important. Specify this level for servers that run important services or store important data.
- General. Specify this level for servers that run general services or store general data.
- Test. Specify this level for servers that run test services or store test data.
Checking Asset Importance
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation pane on the left, choose Servers tab is displayed. . The
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- In the lower part of the tab page, check the asset importance. You can click Important, General, or Test to view servers by importance level.
Specifying Asset Importance
- Select the target servers and click Configure Asset Importance above the list.
- In the dialog box that is displayed, select an asset importance level.
- Confirm the information and click OK.
In the Asset Importance area in the lower left corner, select a level and check whether the importance of assets is correct.
