Updated on 2025-10-10 GMT+08:00
Security Report Overview
HSS provides daily, weekly, and monthly security reports, and allows you to customize the report period. The reports show the statistics on the security trend, key events, and risks of protected servers.
  • Security reports are available in HSS professional, enterprise, premium, WTP, and container editions.
  • A report will be retained for six months after generation.
Security Report Description
By default, weekly and monthly reports are preconfigured in HSS. After protection is enabled for your assets, reports are automatically generated by default. The report content and generation time are as follows:
  • Report content:
    • Security overview: risk trend, risk distribution, top 5 unsafe servers, and top 5 brute-force attack sources
    • Risk management: vulnerability statistics, asset account change records, dangerous open ports, and weak passwords
    • Intrusion detection: unsafe accounts, remote login, malicious programs, web shells, account cracking, and key file changes
  • Report generation time:
    • A default weekly security report is generated between 06:00 and 12:00 every Monday. It contains the statistics of a week, from 00:00 on Monday to 24:00 on Sunday.
    • A default monthly security report is generated between 06:00 and 12:00 every Monday. It contains the statistics generated from 00:00 on the first day to 24:00 on the last day of a month.
You can view security reports. For details, see Checking a Security Report.
If the default report does not meet your requirements, you can create a custom report or edit the default report. For details, see Creating a Security Report and Editing a Report.
