Checking a Security Report
You can check daily, weekly, monthly, and custom reports. The reports show your server security trends and key security events and risks.
This section describes how to view the generated reports.
The enterprise, premium, WTP, or container edition is enabled.
Security Report Overview
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - In the navigation pane on the left, choose Security Operations > Reports.
You can use default security report templates directly, which are default monthly security report and default weekly security report.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click Download to go to the preview page. You can check the information of the target report and download or send it.
Checking Report History
The report history stores the report sending details.
- In the upper right corner of the security report overview page, click Report History to check the report sending records.
- Check the report history on the displayed page, as shown in the following picture. For more information, see Table 1.
- Click Download in the Operation column to check historical reports. You can also preview and download the reports.
