Managing Ransomware Protection Policies
After ransomware prevention is enabled, you can manage its policies as needed. Supported operations include:
- Changing a Policy: If the current protection policy bound to a server cannot meet your requirements, you can bind another policy to the server.
- Modifying a Policy: If you need to modify specific settings (such as the honeypot protection directories or excluded directories), you can modify them in an existing protection policy. When HSS automatically enables ransomware prevention, a protection policy is configured by default. (The default policy for Linux is tenant_linux_anti_default_policy, and that for Windows is tenant_Windows_anti_default_policy.) You can modify them as needed.
- Deleting a Policy: If a protection policy is discarded and not associated with any servers, you can delete the policy.
Only premium, WTP, and container editions support ransomware protection.
Changing a Policy
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- Choose .
- Click the Protected Servers tab.
- Select a server and click Change Policy.
You can also choose Operation column of a server.
in the - In the Change Policy dialog box, select a protection policy.
- Click OK.
Modifying a Policy
- Click
and choose .
- In the navigation pane, choose Server Protection > Ransomware Prevention. Click the Policies tab.
- Click Edit in the Operation column of a policy. Edit the policy configurations and associated servers. For more information, see .
The following uses a Linux server as an example. On the Protected Servers tab, you can also click the name of the policy associated with the server to edit the policy.
Table 1 Protection policy parameters Parameter
Example Value
Policy
Policy name.
Anti_Ransomware
Action
How an event is handled.
- Report alarm and isolate: If a ransomware attack is detected, an alarm will be generated, and the process that attempts to encrypt files will be blocked.
- Report alarm: If a ransomware attack is detected, only an alarm will be reported.
Dynamic Honeypot Protection
A honeypot is a file that simulates actual service files. It can induce attackers and capture ransomware encryption behaviors in real time.
Generally, dynamic and static honeypots are used together for comprehensive protection.
After honeypot protection is enabled, the system will deploy honeypot files in honeypot directories and other random locations. (Honeypot files will not be deployed in the excluded directories specified by users). The honeypot files deployed in random locations are automatically deleted every 12 hours and then randomly deployed again. A honeypot file occupies a few server resources. You can configure excluded directories, and the honeypot files will not be deployed in them.
Dynamic honeypots are more flexible and can better detect ransomware attacks.
This parameter is mandatory only for Linux servers.
Enabled
Honeypot File Directories
Static honeypots are deployed in specified directories. You can add important service directories or data directories as protected directories. Honeypot files will be deployed in these specified directories (excluding their subdirectories). They can distract attackers and slow down their attacks on real resources.
Separate multiple directories with semicolons (;). You can configure up to 20 directories.
This parameter is mandatory for Linux servers and optional for Windows servers.
- Linux: /root;/home;/opt;/var;/etc
- Windows: C:\software
Excluded Directory (Optional)
Directory that does not need to be protected by honeypot files.
Separate multiple directories with semicolons (;). You can configure up to 20 excluded directories.
- Linux: /bin;/boot;/lib;/lib32;/lib64;/lost+found;/proc;/run;/sbin;/selinux;/srv;/sys;/usr/bin;/usr/local/bin;/usr/local/sbin;/usr/sbin;/var/lib/container;/var/lib/kubelet;/var/lib/ntp/proc
- Windows: C:\software\test
Protected File Type
Types of files to be protected.
More than 70 file formats can be protected, including databases, containers, code, certificate keys, and backups.
Select all
(Optional) Process Whitelist
Paths of the process files that can be automatically ignored during the detection, which can be obtained from alarms.
This parameter is mandatory only for Windows servers.
Associate Servers
Information about the server associated with the policy. If you want to disassociate the server (disable ransomware protection), you can delete the policy.
- Confirm the policy information and click OK.
Deleting a Policy
- Click
and choose .
- Click Delete in the Operation column of the target policy.
After a policy is deleted, the associated servers are no longer protected. Before deleting a policy, you are advised to bind its associated servers to other policies.
