Help Center/
Host Security Service/
User Guide (Kuala Lumpur Region)/
FAQs/
Container Security/
How Do I Disable Node Protection?
Updated on 2025-10-10 GMT+08:00
Before You Start
Disabling protection does not affect services, but will increase security risks. You are advised to keep your servers protected.
Disabling the Container Edition
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - In the navigation pane, choose . Click the Container Nodes tab.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- In the Operation column of a server, click Disable Protection.
To disable protection in batches, select multiple target servers and click Disable Protection.
- In the dialog box that is displayed, confirm the information and click OK.
- After the function is disabled, choose . On the Container Nodes tab, if the Protection Status of the server is Unprotected, it indicates protection has been disabled.
Parent topic: Container Security
