Help Center/
Host Security Service/
User Guide (Kuala Lumpur Region)/
Prediction/
Container Image Security/
Viewing Malicious File Detection Results in Images
Updated on 2025-10-10 GMT+08:00
Malicious files in the private images can be automatically detected, helping you discover and eliminate the security threats in your assets.
Check Frequency
A comprehensive check is automatically performed in the early morning every day.
- This function is available only in the HSS container edition.
- Only malicious files in Linux images can be detected.
- Click
in the upper left corner and select a region or project. - In the upper left corner of the page, click
and choose . - In the navigation tree on the left, choose Prediction > Container Images.
- Click the Malicious Files tab to view details about the malicious files in private images. Delete the malicious files or create images again as needed based on the scan result.
- Malicious files include Trojans, worms, viruses, and Adware.
- In the Image Tag column, click an image version to view its vulnerability report.
Parent topic: Container Image Security
