Viewing SWRImage Repository Vulnerabilities
This section describes how to view SWR image repository vulnerabilities and fix the vulnerabilities as prompted.
Container node protection has been enabled.
Only vulnerabilities in Linux images can be checked.
Viewing Vulnerabilities in SWR Images
- Click
in the upper left corner and select a region or project.
- In the upper left corner of the page, click
and choose .
- In the navigation tree on the left, choose Prediction > Container Images.
- Click the SWR Image Repository Vulnerability tab to view the system and application vulnerability lists. For details about the vulnerability list, see SWR image repository vulnerability parameters
Table 1 SWR image repository vulnerability parameters Parameter
Vulnerability Name
You can click a vulnerability name to view basic information about a vulnerability and the images affected by the vulnerability.
Repair Urgency
You are advised to fix vulnerabilities of the high and medium levels.
Historically Affected Images
Images affected by the vulnerability.
Solution
HSS provides a recommended solution to the vulnerability. Click the solution description to go to the details page.
