Baseline Check Overview
What Is a Baseline Check?
Baselines specify the recommended security configurations for OSs, databases, middleware, and applications. They include the configurations of permissions, services, network, password security, and DJCP MLPS compliance.
HSS can check password complexity policies, common weak passwords, and other settings to detect insecure passwords and the configuration risks in systems and critical software. It also provides suggestions to help users correctly handle unsafe settings on servers.
Baseline Check Content
Check Item |
Description |
Supported HSS Edition |
Baseline check |
Check the unsafe Tomcat, Nginx, SSH login, and system configurations found by HSS. The following systems, databases, and applications can be checked:
Enterprise, premium, WTP, and container editions |
Password complexity policies |
Check whether your password complexity policy of Linux system account is proper and modify it based on suggestions provided by HSS, improving password security. |
All |
Common weak passwords |
Weak passwords defined in the common weak password library. You can check for the weak passwords used by accounts and remind users to change them. Linux supports weak password detection for MySQL, FTP, Redis, and system accounts. Windows supports weak password detection for system accounts. |
All |
Usage Process
No. |
Operation |
Description |
1 |
The baseline inspection supports automatic and manual baseline checks.
2 |
After the baseline inspection is complete, you need to view and handle baseline configuration risks. |
